[NEBULA] Content Filtering
HI,
i'm tryng to configure my nebula Gateway, NSG50, but i can't block url.
In the screenshot attached my configuiration, for example from i client i can acces www.yonkis.com but in the configuration is correctly identified by the content filtering.
thank you!
Yes I try but no run.
Hello @Keys
Welcome to Nebula Community!! ?
I will PM you for the access privilege please check your Inbox message for the detail information.
/Chris
Same issue for me, this feature seems broken? Machines are still able to access Netflix..
Can you post the solution please?
The solution has been made to me in Nebula_Chris
Can you share what he did?
Hello @Pook and the Community,
Recently we have addressed this issue and will release the fix firmware on 13/1, 2020.
You can find the upgrade now button at Site-Wide>Firmware management and please be aware to re-active the Content Filtering after the upgrade. ?
/Chris
Thanks Chris, the firmware is already up to date though. Unless you mean there is a new firmware out on the 13th?
So does this mean content filtering has never worked? Or is it currently just down to to the new releasecoming out?
Hi @Pook ,
It's probably the device didn't apply Content Filtering configuration.
The fix firmware (1.33 patch 2) has release today, so you can upgrade it now.
Feel free to let me know if the issue still remain.
/Chris
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
