[NEBULA] 1 User limit on L2TP Connection
Pook
Pook Posts: 153 image  Master Member
First Comment First Answer Friend Collector Nebula Gratitude
edited April 2021 in Nebula
Hey Guys
So today I have another weird issue, an NSG100 is only allowing one VPN client at a time. When more than 1 user connects the other drops. Anyone seen this before?
  • Pook
    Solved, VPN DHCP scope ended in /32 so only 1 ip was available.
  • Pook
    Ok so it turns out it's the whole organization, only 1 client can connect at a time.
  • Pook
Nebula Tips & Tricks
