Nebula SD-WAN upgrade units
PLAN42
PLAN42 Posts: 2  Freshman Member
First Comment Nebula Gratitude
edited April 2021 in Security
Hi
The only category for SD-WAN I could find were in the Polish forum, but I hope it's ok with my school-english.. :)
Having a problem upgrading units attached to my SD-WAN.
When addressing them individually I get the message they are managed in SD-WAN, which should be correct.
When addressing them via Nebula the upgrade button (the cloud symbol on image) seems to have no action. How do you adress upgrading?
/Patrick
  • Zyxel_Vic
    Zyxel_Vic Posts: 283  Zyxel Employee
    25 Answers First Comment Friend Collector Seventh Anniversary
    edited January 2020
    Hi @PLAN42
    Could you authorize our support account to your GROUP so that we can help to check further on your device and see what's going on there?
    Here it is our support account:
    cso_security@zyxel.com.tw
    Just add this account into the Administrators list then we'll be able to check for you.
  • PLAN42
    Arranged!
    /Patrick
  • Zyxel_Vic
    Hi @PLAN42
    We've seen the symptom on your device and now checking on it. This issue will be solved soon on the portal, I'll let you know when it's done.
    Thank you for the kindly feedback.
