Nebula SD-WAN upgrade units
Hi
The only category for SD-WAN I could find were in the Polish forum, but I hope it's ok with my school-english.. :)
Having a problem upgrading units attached to my SD-WAN.
When addressing them individually I get the message they are managed in SD-WAN, which should be correct.
When addressing them via Nebula the upgrade button (the cloud symbol on image) seems to have no action. How do you adress upgrading?
/Patrick
Hi @PLAN42
Could you authorize our support account to your GROUP so that we can help to check further on your device and see what's going on there?
Here it is our support account:
cso_security@zyxel.com.tw
Just add this account into the Administrators list then we'll be able to check for you.
Arranged!
/Patrick
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
