autmatic reconnection from client side
SDL
SDL Posts: 4 image  Freshman Member
edited April 2021 in Security
Hello
Is there a possibility to automatic reconnect VPN when the tunnel is broken? We have a client were the router sometimes looses connection. So, the Zyxel shall reestablish the VPN connection automatically.
  • [Deleted User]
    [Deleted User] Posts: 213 image  Freshman Member
    Hello @SDL an welcome to the forum,
    can you let me know if we are talking about SSL VPN or IPsec VPN (SecuExtender or IPsec client).
    Many thanks.
    Best regards
    Lukas
  • SDL
    I use IPsec VPN. Does it help when I configure site to site?
  • Blabababa
    Blabababa Posts: 151 image  Master Member
    Just found related settings on the IPSec VPN client software, is it what you need?
  • SDL
    Sorry, but I can't find this in my configuration!!
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @SDL, @Blabababa ,
    The screenshot @Blabababa provided is the software of the IPSec VPN client on PC, not on our device web gui.
    You can setup the VPN Wizard again to modify the VPN setting on EZmode.
    Enable the Nailed-Up function to allow VPN auto-reconnect.
    And you can check the settings here.
    Go to Configuration > VPN > IPSec VPN > VPN Connection > Edit the VPN Connection > General Settings > Advance
  • SDL
    Thanks !!!?
