minor bug on DHCP option
sebala
sebala Posts: 18 image  Freshman Member
First Comment Seventh Anniversary Nebula Gratitude
edited April 2021 in Nebula
There is a minor issue when setting DHCP Option in Nebula 2.0 GUI.
If you select an option (for exemple NTP) then you come back to User Defined, you cannot change the Type field anymore.
  • Zyxel_Chris
    Zyxel_Chris Posts: 739 image  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    Hi @sebala
    Many thanks for your feedback?️
    we'll working on it and update in the post once fix it.
    /Chris
  • Zyxel_Chris
    @sebala
    This issue has been fixed today, feel free to let us know if the problem still persist.?
    /Chris
Nebula Tips & Tricks
