zywall usg210 - SMTP authentication parameters vanished
phphil
phphil Posts: 39 image  Freshman Member
edited April 2021 in Security
We just noticed that we don't receive anymore the Daily report via email, I checked under Configuration > Log & Report > E-mail Daily Report and I discovered that the SMTP autentication config parameters are not there anymore. I'm talking about the 3th red squared section.
Untitled Image
We recently upgraded the firmware to the latest version (is that a known issue?)
And we also recently enabled SecuReporter.
How/where can I fix configuration in order to receive again the Daily report?
Thank you
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,401 image  Zyxel Employee
    Hi @phphil ,
    Which firmware version are you using before upgrading to the current one and can you send your original config file to us in private message to check further?
  • phphil
    edited February 2020
    Thank you for the reply Zyxel_Jerry,
    Unfortunately is not possible for me to send the config file due to our security policy, but I may be allowed to communicate privately certain config parameters.
    Before the latest upgrade, the firewall was running the closest one: Version V4.35(AAPI.0)
    currently we are on 4.35(AAPI.2)
    Currently we cannot see the SMTP authentication section, as shown in the following screenshot:
    Which specific information can I provide to you?
    Thank you
  • Zyxel_Jerry
    Hi @phphil ,
    This configuration had been moved to Notification > Mail Server
    You can find the SMTP Authentication settings here.
    CONFIGURATION > System > Notification > Mail Server
  • phphil
    Thank you,
    Some parameters was changed, apparently from the firmware update
    solved
