Layer-2 isolation and subnet problem
Y_L
Y_L Posts: 2 image  Freshman Member
edited May 2024 in Wireless
I'm trying to setup a guest wifi with layer-2 isolation on a WAC6103D-I but i can't get it working properly.
I have added mac adresses of "VPN GW" and "Internet GW" in my Layer-2 Isolation profile but it still allows users to browse web servers on the main site and internet sites.
If i remove VPN GW from my list, i can't connect to anything.
I have successfully configured another AP with a guest wifi and Layer2-Isolation on my main site without trouble.
What can i do to really isolate users on my guest Wifi?
Thanks!?
  • livealive
    livealive Posts: 23 image  Freshman Member
    Hi @Y_L
    What's your guest Wifi scenario? Do you mean you don't wanna the guest to access your main site or the guests cannot communicate with each other or else?
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi @Y_L
    Welcome to ZYXEL community.
    Layer-2-isolation is used to block same subnet client can’t communicate with each other. If a device’s MAC addresses is NOT listed in a layer-2 isolation profile, it is blocked from communicating with other devices in an SSID on which layer-2 isolation is enabled.
    Since you added the  mac addresses of "VPN GW" and "Internet GW" in Layer-2 Isolation profile, it means that these two devices are allowed to be accessed by other devices in the SSID to which the layer-2 isolation profile is applied. So, the Guest Wifi clients can access the internet and intranet.
    If you want to isolate Guest Wifi in the office, just create a Layer-2-isolation profile without any whitelists.
    Hope it helps.
    Joslyn.
  • Y_L
    I think that the answer is here: "same subnet".
    It's not my case, so in this configuration i can't use Layer-2 Isolation.
    The goal is to isolate my "guest wifi" users from everything. I just want them to access internet through the "Internet GW" located in my main site.
    I'll have a look to my firewall config.
    Thank your very much for your help! ?️
    Yann
