Whatsapp
Carlos
Carlos Posts: 1 image  Freshman Member
edited April 2021 in Security
Como hago para descgar imagenes desde whatsapp...el firewall bloquea la descarga de imagenes desde el whatsapp
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @Carlos
    Welcome to Zyxel Community.
    You can go to Monitor > Log > View Log to check out which firewall rule blocked the whatsapp.
    2020-02-06 13_57_00-[usg210] (10.214.48.29) - .__ Welcome to 'USG210' __..png
    The forum support for English, please post in English so that other people who is interested in the same topic will be able to join the discussion.
  • ChrisGer
    ChrisGer Posts: 206 image  Ally Member
    Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
    Hi @Carlos
    I remember there are several patterns to config, to enable picture download.
    But be carefull, WhatsApp is a part of Facebook Inc. and require additional ports for successfull communication. It's a bit tricky to reduce the communication.
    Regards
    Christian
  • LAURAM
    LAURAM Posts: 13 image  Freshman Member
    First Comment First Answer Friend Collector Sixth Anniversary
    Hi @sheemer
    I'm using V5.00 firmware. The whatapps can be blocked.
  • john42417
    john42417 Posts: 1 image  Freshman Member
    You can change the setting from your device which one you using. sometimes automatically setting puts some restriction on our application you just need to find out to make it correct.
