ZyWall USG 1100 routing
Do it, nothing. Add reverse policy rout from 192.168 to 172.20. Not.
On full log on Lan1, there 172.20. & 172.21.
Do nslookup from 192.168.13.1 to 172.20.0.2.
In logs nothing from 192.168.13.1 to 172.20.0.2.
From 172.20.0.2 has answer to 192.168.13.1 on udp:53. It is accept.
As i see, the problem is that 192.168 lan goes directly to 172.20. via 172.20.0.99. Not via Zywall.0 -
Thanks all for help. We found solution by the simplest way. Contakt with provider of 2nd VPN, reconfig gw to 192.168.0.99 on ZyWall, and all work properly.0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
