Is It Possible To Change The Format Of E-Mailed Reports
Zyxian
Zyxian Posts: 8 image  Freshman Member
edited April 2021 in Security
Hello all.
I have a USG20-VPN. When I get the e-mailed report, I copy it into Word and it looks like this:
As you can see, it splits each line in the Log into 4 lines. What do I change so the e-mailed report looks like what the USG20-VPN shows when I look at the logs there?
Thank you for any help provided.
Zyxian
  • Zyxel_Vic
    Zyxel_Vic Posts: 323 image  Zyxel Employee
    25 Answers First Comment Friend Collector Eighth Anniversary
    Hi @Zyxian
    Thank you for the feedback, currently it's not supported to modify the layout at this moment. We will evaluate about how can we make this layout become more user friendly.
  • Zyxian
    Thank you Vic.
    A CSV file would be a good start. An easy import to Excel.
    Zyxian
  • Zyxel_Vic
    Hi @Zyxian
    You can also consider to use a log server to collect the exported log
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,405 image  Zyxel Employee
    edited February 2020
    Hi @Zyxian
    Thanks for your feedback and we are considering to attach the log as a file in the mail attachment to avoid any kind of mail layout problem.
    If you have any suggest about the format of email report, you may also share your comment with us.
