Why does my new USG 60 only allow half internet speed
Recently after no changes made to my firewall, my lan speed has dropped from 1Gb up/down to 250Mb up/down. No changes to network. We experienced a brief lan outage that came back after 5 minutes. Since that outage the slow speeds are all we see.
Direct connect to router shows 1Gb up/down.
Tried many things, Last was hardware reset the USG 60, still slow.
If I turn firewall off from easy screen, speeds bump up to 450Mb up/down.
Unit is 3 months old, It appears to me to be a hardware issue internal to the USG60
Prior to the above mentioned lan bump all was working as expected.
Any insight to this is appreciated.
For discussion in English - https://businessforum.zyxel.com/categories/security-zywall-usg-series
5
5 -
Thanks I will go look
HelloI have the same problem with the USG60W.I normally have an internet speed non 1000 MBit/s. The USG60W only reaches 400 Mbps.This is despite the fact that all services are deactivated.The above link is no longer valid0
Hi @DanielEssl,
You can enable Fast Forwarding function which should improve the performance. (Configuration > System > Advanced > Fast Forwarding)
- 603 USG FLEX H Series
- 481 News and Release
