Not open a site web
CiroB
CiroB Posts: 4  Freshman Member
edited April 2021 in Security
I own a USG40, suddenly a specific website that I use daily does not open from any PC on the net.
provided that I have not changed anything in the zywall configuration.
someone can elucidate me I don't know where my head is going anymore.
thank you
    PeterUK Posts: 4,036  Guru Member
    Do you use any UTM options?
    The site could be blocking you or a routing issue so run in the USG diagnostic > network tool a TRACEROUTE IPv4
  • CiroB
    Thanks for the reply.
    I don't use utm profiles.
    here is the result of the traceroute. (for privacy I covered the addresses)
    edited February 2020
    Why can't you just post the site?
    From what I can make out of a bad screenshot the USG can ping the site so maybe run a tracetcp from a PC.
    https://simulatedsimian.github.io/tracetcp.html
  • CiroB
    The site is www.difesa.it
    I suspect the site is blocking you can you run a tracetcp from a PC?
    Can you get another WAN IP? or by connecting a PC to the modem?
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,376  Zyxel Employee
    Hi @CiroB
    After failed to access the specific website.
    You can go to Monitor > Log > View Log to check which rule blocked the specific websites.
    Zyxel
    Untitled Image
