[NEBULA] CAPTIVE PORTAL > long Message on Click-to-continue/Sign-on page
Hi @Gianmarco,
Sorry that it's a limitation for the AP to put too many text, however, we plan to enhance it in this year.
So far, we suggest that you can use external captive portal page or use the the HTML code to insert an external link for the long text.
Please note that if you use the the HTML code to insert an external link for the long text, it's necessary to add the link to wall garden.
Thanks.
Hello @Gianmarco,
There's another workaround for the long text that you can edit the HTML on the copied captive portal theme in AP> configure> Captive portal as below.
Thanks.
- 221 Nebula Ideas
- 612 USG FLEX H Series
- 53 Wireless Ideas
- 483 News and Release
