Import existing standalone configuration
Hey there,
we're currently running a few GS1920 and GS1920v2 in our environment and I would like to join them into the Nebula Cloud.
Is there an easy way to join the device without loosing it's configuration? Or is exporting the configuration before joining and applying all changes by hand the only option?
Thank you very much in advance
Hi @Waishon ,
First of all, please note that GS1920 doesn't support Nebula, only GS1920v2 supports Nebula.
In current design, Switch will reset to default when it changes to cloud mode, so you have to re-configure those features you need and they are also supported in cloud mode on NCC.
We still need more time to discuss about this because not all standalone mode features are also supported in cloud mode currently. I will help you move this post to idea section.
Thanks and hope you understand.
- 601 USG FLEX H Series
- 480 News and Release
