[NEBULA] External Captive Portal authentication
Hi @SB10,
Thanks for your clarify and sharing the information. We'll check it and fix this issue asap.
Awesome finding @SB10! My SSIDs do not contain symbols that's why I didn't experienced the same. Thanks for the warning! Hopefully this can be fixed tho.
Thanks @Nebula_Freda
Btw, is there any update or maintenance going on right now?
I am only getting "apmac" in the URL at the moment
Edit: looks like it works now, i don't know why that happened
Hi @SB10 ,
After we checked, there's no abnormal on NCC server at the time you posted, so would you screenshot for us if the NCC displays incorrect.
For the SSID with '#' symbol issue, we have a date firmware for fixing it, and please let me know if you need it.
Thanks.
The '#' character is something i can survive without, i will just not use it in the SSID, but it would be nice to fix that for future users.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
