SSL WEB Application
Raf
Raf Posts: 2 image  Freshman Member
edited April 2021 in Security
Hello!
I have an USG40 behind a natted router on my WAN with IP 192.168.100.1
I have moved https from port 443 to 44443 to have less "noise" on log file :)
I have a Tomcat  server on my LAN1 side http://192.168.10.20:9099/csa/
I have configured SSL Application with these parameters:
Server Type "Web Server"
Entry Point:  "/csa/"
I have also tried to omit the optional entry point BUT when I connect with SSL VPN user, and I start the "MYTomcatApp" I obtain this result: (from ANY browser)
Bad Gateway
The proxy server received an invalid response from an upstream server.
Additionally, a 400 Bad Request error was encountered while trying to use an ErrorDocument to handle the request.
In the log file I see only this:
7    2019-04-26 11:18:13  info    SSL VPN        web application MYTomcatApp has been accessed. sent=958 rcvd=141 [count=4]
8    2019-04-26 11:17:54    info    SSL VPN        User user1 has accessed web application MYTomcatApp [count=2]
What I miss to configure?
I tried also with others web servers in my LAN but with same results.
Thank you in advance
«1
  • Zyxel_Stanley
    edited April 2019
    Hi @Raf
    Your configuration should be correct.
    For resolving this issue I will send you private message to get more detail information.
  • Zyxel_Stanley
    Hi @Raf
    The revers proxy mode is coding by Java. Since Java have some of security concern.
    So many browser may not support any more.
    We would like to suggest you use full tunnel mode(SecuExtender) for this scenario.
  • Raf
    Yes, I do .
    Raffaele
  • ADIATIC
    ADIATIC Posts: 1 image  Freshman Member
    we are currently facing the same problem but we can't solve it, can you please tell us the procedure?
    Thank you
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @ADIATIC
    As @Zyxel_Stanley previous mentioned
    By using SecuExtender, you can build up tunnel to the device, then you can login to your server.
    Here is the step to setup SSL VPN on USG with SecuExtender to login.
    Go to Configuration > VPN > SSL VPN > Access Privilege > Add SSL VPN rule
    Add user for SSL VPN
    Add IP range for SSL VPN
    Select User/Group
    Enable Full Tunnel Mode for SSLVPN tunnel
    Assign IP Pool for SSL VPN rule
    Select the Network to allow user to access.
    Test result
  • SyoSilIT
    SyoSilIT Posts: 3 image  Freshman Member
    edited August 2020
    thanks, I already got SecuExtender to work 100% but I thought the idea for SSL applications was that you could add a user in the router to access in internal website without the SecuExtender. E.g. For instance, allow a client to access a bug tracking system internal to your network...?
    Thaks, JSA
  • Zyxel_Emily
    If you're using SecuExtender (full tunnel mode) to establish SSL VPN to USG/ZyWALL, you don't need to configure SSL application.
  • SyoSilIT
    edited February 2021
    Agree but maybe I am on a computer where I cannot run the full SSL VPN application then this feature would be very handy. In the scenario that I am in then I cannot run the SSL VPN in full tunnel mode or do SSH or anything. This feature would solve my problems but it seems like it has been left behind for years and it is not updated to meet the standards of current browsers. Why not just remove it?
  • Zyxel_Vic
    Zyxel_Vic Posts: 323 image  Zyxel Employee
    25 Answers First Comment Friend Collector Eighth Anniversary
    Hi @SyoSilIT
    Thanks for your suggestion and yes we're considering the same idea since it is deprecated now days.
