Not open a site web
Hello, I own a USG40, suddenly a specific website that I use daily does not open from any PC on the net. provided that I have not changed anything in the zywall configuration. someone can elucidate me I don't know where my head is going anymore. thank you
Do you use any UTM options?
The site could be blocking you or a routing issue so run in the USG diagnostic > network tool a TRACEROUTE IPv4
Thanks for the reply. I don't use utm profiles. here is the result of the traceroute. (for privacy I covered the addresses)
Why can't you just post the site?
From what I can make out of a bad screenshot the USG can ping the site so maybe run a tracetcp from a PC.
The site is www.difesa.it0
I suspect the site is blocking you can you run a tracetcp from a PC?
Can you get another WAN IP? or by connecting a PC to the modem?
Hi @CiroB
After failed to access the specific website.
You can go to Monitor > Log > View Log to check which rule blocked the specific websites.
Zyxel
- 439 Beta Program
- 190 Nebula Ideas
- 6.2K Security
- 466 USG FLEX H Series
- 305 Security Ideas
- 81 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
