IPSec VPN subnet Lan1 is not reachable
eifelrudi
eifelrudi Posts: 11  Freshman Member
edited April 2021 in Security
i have two IPSec Connection - same gateway.
Both connections are absolut identical, only the local network (Subnet) is ...
  1. lan1-Subnet (192.168.10.0/24)
  2. vlan10-Subnet, based on lan1 (192.168.200.0/24)
If i connect to 2. Connection, everything is fine - can reach each device on vlan 10
Connecting to 1. connection, i can only reach the router itself, but no device on lan1.
  • eifelrudi
    sorry, i have found the solution in my configuration.
    the destination IPs (TPLink-Switches) are only reachable for admin, when source-ip is in VLAN1.
  • eifelrudi
