[NEBULA] Make a policy route through vpn
Best Answers
Hi Yes I have site to site vpn. My problem is that from my pc that is hooked up via L2TP vpn can i ping the NSG100 ip address which is on hooked up via site-to-site vpn but i can't pinging client pi address which is on the same subnet. That's why I thought I would create a policy route via vpn to the client.
h
Olav0 -
Hi @Elgen007 ,
I assume that you are using Server-and-Client VPN, if yes, for the current designed Server-and Client don't support policy route, due to the priority of VPN is higher than policy route.
For the workaround, if not necessary, we will recommend you using site-to-site or hub-and-spoke.
Thanks for understanding.
Jonas
Jonas,5
Have you already configured site-to-site VPN??
h
Olav0 -
Hi @Elgen007 ,
Jonas
Jonas,5 -
Hi
Clarification, yes I use Server-and-Client VPN and I understand that's why I can't use policy routing, but I don't quite understand why.
h
Olav
- 588 USG FLEX H Series
- 477 News and Release
