[NEBULA] Changing from Shared Key for APs to individual user authentication.
Hi @Jbird,
To using the authentication for each user, you may change the authentication to WPA2-Enterprise in Access Point> Configure> Authentication.
There are two types for WPA2-Enterprise, Nebula cloud authentication and My Radius server. When you select the Nebula cloud authentication, you can add the user accounts in Organization-wide/Site-wide> Configure> Cloud authentication, or use the pro-pack feature to import all user account.
For My Radius server, please enter the Radius server information on NCC as below.
Thanks.
5
Hi @Jbird,
Thanks.
5 -
Can I setup all of the users ahead of time and then turn the Cloud Authentication on?
I have another question. I've setup a user and turned on the WPA-2 Enterprise as described previously, and authorized the user, but I still can't login. What am I missing??
Never mind. I answred my own questions.
Thanks for the help!!
Hi @Jbird,
Yes, you can edit the users in the list anytime before or after you turn on the Cloud authentication.
Thanks.
- 441 Beta Program
- 292 Service & License
