WLAN time-controlled and protocol more than 500 entries
bdb
bdb Posts: 11 image  Freshman Member
edited April 2021 in Security
Hallo,
ist es möglich das WLAN zeigesteuert an und aus zu schalten? Eventuell mit einen Skript?
Zudem würde mich interessieren ob ich das Protokoll auch dazu bringen kann mehr als 500 Einträge zu speichern?
Danke für eure Hilfe!
  • bdb
    hier in Englisch:
    is it possible to switch the WLAN on and off with display control? Maybe with a script?
    I would also like to know if I can make the protocol save more than 500 entries?
    Thanks for your help!
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @bdb
    On models such as USG20W/USG40W/USG60W.
    You can enable and disable the function WLAN control on easy mode dashboard.
    The user defined protocol can reach up to 255 protocol.
    You can add your Service Rule by following steps.
    Go to Configuration > Object > Service> Service > Add
  • bdb
    That wasn't exactly my question. I guess I wasn't clear either.
    I would like to have the WLAN switched on and off automatically and time-controlled.
    Regarding protocol I didn't mean the TCP but the LOG entries. No more than 500 are stored here.
  • Zyxel_Jerry
    Hi @bdb
    May I know what model and firmware are you current using?
  • bdb
    Hi @Zyxel_Jerry,
    Model: USG20W-VPN
    Firmware: V4.35(ABAR.2) / 2019-11-23 21:22:23
  • Zyxel_Jerry
    Hi @bdb
    1 . The schedule can be setup by following steps.
    Go to Configuration > Object > AP Profile > SSID > SSID List > select the rule > Edit the rule
    Arrange the schedule of SSID
    2 . The current design of the log display on USG20W-VPN is up to 512 entries,
    If need to save more logs, then route the logs to an external host .
    Go to Configuration > Log & Report > Log Settings > select the Remote Server > Edit
    2020-02-25 11_22_51-2020-02-25 11_22_29-https___10.214.48.68_ext-js_index.html#.png
    Select the log need to be collect
