Thershold of hardware monitor
VictorZX
VictorZX Posts: 7
edited August 2022 in Switch
Hello I configured snmp service in XGS2210-24 switches so traps are sent to a snmp monitor. I have a question about this traps
zyHwMonitorFanSpeedOutOfR ange
zyHwMonitorTemperatureOut OfRange
zyHwMonitorPowerSupplyVolt ageOutOfRange
What is the threshold of that alarms that indicate that exist a problem in switch.?
I saw this image
I guess if mac temperature goes above 85, will switch send a trap?
I guess if fan1 speed goes below 500, will switch send a trap?
In voltaje section what mean of +-%6??
Thanks in advance
  • Sorry, my switch is XGS3370
  • And what is the threshold with this traps
  • [Deleted User]
    [Deleted User] Posts: 213
    Hello @VictorZX,
    I have moved your post to the english switch section.
    Best regards
    Lukas
  • Zyxel小編 Lucious
    Zyxel小編 Lucious Posts: 279
    25 Answers First Comment Friend Collector Third Anniversary
    edited March 2020
    Hi @VictorZX
    Kindly see my reply in bold.
    I guess if mac temperature goes above 85, will switch send a trap? Correct.
    I guess if fan1 speed goes below 500, will switch send a trap? Correct.
    It means +-6% of the rated voltage.
    For example of rated 5V, 6% threshold of 5V equals 0.3V.
    In case the rated 5V is detected lower than 4.7V or higher than 5.3V, the switch will send a trap.
    The zyHwMonitorPowerSupplyVoltageOutOfRange monitors rated voltages in the HW monitor table.
    By the way, remember to check the trap options in Management -> Access Control -> SNMP -> Trap Group in case you need to monitor them via SNMP trap.
    Zyxel_Lucious
