Thershold of hardware monitor
Hello I configured snmp service in XGS2210-24 switches so traps are sent to a snmp monitor. I have a question about this traps
zyHwMonitorFanSpeedOutOfR ange
zyHwMonitorTemperatureOut OfRange
zyHwMonitorPowerSupplyVolt ageOutOfRange
What is the threshold of that alarms that indicate that exist a problem in switch.?
I saw this image
I guess if mac temperature goes above 85, will switch send a trap?
I guess if fan1 speed goes below 500, will switch send a trap?
In voltaje section what mean of +-%6??
Thanks in advance
Sorry, my switch is XGS3370
And what is the threshold with this traps
Hi @VictorZX
Kindly see my reply in bold.
I guess if mac temperature goes above 85, will switch send a trap? Correct.
I guess if fan1 speed goes below 500, will switch send a trap? Correct.
It means +-6% of the rated voltage.
For example of rated 5V, 6% threshold of 5V equals 0.3V.
In case the rated 5V is detected lower than 4.7V or higher than 5.3V, the switch will send a trap.
The zyHwMonitorPowerSupplyVoltageOutOfRange monitors rated voltages in the HW monitor table.
By the way, remember to check the trap options in Management -> Access Control -> SNMP -> Trap Group in case you need to monitor them via SNMP trap.
Zyxel_Lucious
- 237 Nebula Ideas
- 6.8K Security
- 747 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
