[NEBULA] How to set up a Deny Group
         I come from the USG series and utilized heavily the Address Group feature inside the Object-Address area to create a DENY_LIST which I could add various addresses that I did not want trying to access our network. Below is a similar group named ALLOW_LIST from one of our old USG's which had various IP's added to it.
How is this duplicated on a NSG100? I cannot locate any method to create a deny list in it.
Thank you,
            Hello @Jim_Anderson, Welcome to Zyxel Community! Nebula Gateway was designed for plug & play usage. There is no need to be complex to achieve your goal on NSG, please go to New Nebula => Security gateway => Configure => Firewall, as figure below. You may just add various addresses, and then select deny. Note: Please use comma sign "," to add more IP. Hope it helps. Jonas Jonas,0
            Thank you. That works well. Is there anywhere here where a guide exists that would assist users familiar with USG configuring could reference that details how it should now be handled in NSG devices? 0
            Hi @Jim_Anderson, You are very welcome. For the guides, please refer to the link below: (starts at page 89) https://bulletin.nebula.zyxel.com/online-doc/nebula-cc/NCC_UG_v8.20_20200117.en-us.pdf Hope it helps -Jonas Jonas,0
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 497 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
