[NEBULA] How to set up a Deny Group
I come from the USG series and utilized heavily the Address Group feature inside the Object-Address area to create a DENY_LIST which I could add various addresses that I did not want trying to access our network. Below is a similar group named ALLOW_LIST from one of our old USG's which had various IP's added to it.
How is this duplicated on a NSG100? I cannot locate any method to create a deny list in it.
Thank you,
Hello @Jim_Anderson,
Welcome to Zyxel Community!
Nebula Gateway was designed for plug & play usage. There is no need to be complex to achieve your goal on NSG, please go to New Nebula => Security gateway => Configure => Firewall, as figure below. You may just add various addresses, and then select deny.
Note: Please use comma sign "," to add more IP.
Hope it helps.
Jonas
Jonas,0 -
Thank you. That works well. Is there anywhere here where a guide exists that would assist users familiar with USG configuring could reference that details how it should now be handled in NSG devices?
Hi @Jim_Anderson,
You are very welcome.
For the guides, please refer to the link below: (starts at page 89)
https://bulletin.nebula.zyxel.com/online-doc/nebula-cc/NCC_UG_v8.20_20200117.en-us.pdf
Hope it helps
-Jonas
Jonas,0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
