RDP most secure way
Franc
Franc Posts: 27 image  Freshman Member
edited April 2021 in Security
Dear,
I have to connect from WAN to LAN Computers by RDP.
I have used NAT and firewall policy, it works but I read that it's not a secure way to do this.
Please, any suggest about?
Thank-you
    PeterUK Posts: 4,446 image  Guru Member
    edited March 2020
    What you can do is on the remote PC connecting to your USG then to RDP is setup NO-IP on the remote PC then on the USG use FQDN to the subdomain and firewall policy the source IP for RDP with the FQDN.
  • Franc
    thank-you. I didn't know the FQDN I'll read about and I test it.
    I also add the user authentication
