Can’t find local machines by hostname- USG40
Hi @thug
Welcome to Zyxel community
I tested locally without any issue, I can ping the device on the network via its hostname.
Can you private message your configuration for check further?
Zyxel
Hi thug while foraging through these terrific Zyxel forums looking for something unrelated I updated this thread the might be of assistance to you DNS not working on your USG40
Here is the link on these forums:
https://businessforum.zyxel.com/discussion/4005/dns-resolution#latest
Fundamentally this USG40 I'm hooked into currently and several of our clients' USG60's and USG20VPN's had this same issue described in the post above. These appliances had been in service for several years and started misbehaving like this around V4.32 firmware time.
If your symptoms are similar to those described in the post, you might consider resetting and restoring the .conf file and restarting again .. this fixes this immediately.
As per my comments in that post, I'd be most curious if this was was your issue and if resetting and restoring resolved it .
HTH
warwick
Hong Kong
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 485 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
