Mesh AP's as wireless bridge
Hi @TAPTech
Do you mean an option for the Nebula AP to connect two wired networks through a wireless bridge?
Regards,
Barney Gregorio
Hi Barney,
Yes, that is what I mean. We aren't necessarily looking to bridge entire networks together, but being able to plug in one wired device to a Nebula AP that is using a Wireless backhaul would be great!0 -
Hi @TAPTech
This feature will be supported before the end of 2019.
Please look forward to the coming Nebula releases!
Cheers,
Barney Gregorio2 -
Great! Thank you Barney.0
Hi @Nebula_Barney ,
Any update on this? Is this available with any models yet?
Hi @TAPTech
We rearrange the schedule for some reasons, and it will be supported in June this year.
For your reference.
Joslyn
Thanks for the update Joslyn. I'm looking forward to it!
Looking forward to use this feature
Hello, i tried the configuration with NWA1123-AC PRO in a mesh network (Second NWA1123-AC as root) with power adapter over the POE/Uplink Port.
Wifi reapeating is fine, unfortunatley network over a connected Notebook (at LAN1 port) does not work.
Is this a firmware issue in V6.25(ABHD.2) (maybe still not supported) or do i miss something else?
Thanks for your help, best regards.
Old thread, and still not implemented?!?!
- 588 USG FLEX H Series
- 477 News and Release
