[NEBULA] How to set up a Deny Group
Jim_Anderson
Jim_Anderson Posts: 2 image  Freshman Member
edited April 2021 in Nebula
I come from the USG series and utilized heavily the Address Group feature inside the Object-Address area to create a DENY_LIST which I could add various addresses that I did not want trying to access our network. Below is a similar group named ALLOW_LIST from one of our old USG's which had various IP's added to it.
How is this duplicated on a NSG100? I cannot locate any method to create a deny list in it.
Thank you,
  • Zyxel_Jonas
    Zyxel_Jonas Posts: 313 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fifth Anniversary
    Hello @Jim_Anderson,
    Welcome to Zyxel Community!
    Nebula Gateway was designed for plug & play usage. There is no need to be complex to achieve your goal on NSG, please go to New Nebula => Security gateway => Configure => Firewall, as figure below. You may just add various addresses, and then select deny.
    Note: Please use comma sign "," to add more IP.
    Hope it helps.
    Jonas
    Jonas,
  • Jim_Anderson
    Thank you. That works well. Is there anywhere here where a guide exists that would assist users familiar with USG configuring could reference that details how it should now be handled in NSG devices?
  • Zyxel_Jonas
    edited March 2020
    Hi @Jim_Anderson,
    You are very welcome.
    For the guides, please refer to the link below: (starts at page 89)
    https://bulletin.nebula.zyxel.com/online-doc/nebula-cc/NCC_UG_v8.20_20200117.en-us.pdf
    Hope it helps
    -Jonas
    Jonas,
Nebula Tips & Tricks
