USG310 - forget about Manual to do first setup
Rafff
Rafff Posts: 15 image  Freshman Member
edited April 2021 in Security
USG310 just arrived to replace our old and trusty USG300. Download the User Manual which reports, right on the cover: "LAN Port IP Address https://192.168.1.1"
On page 35 we read: "Make sure your Zyxel Device Hardware is properly connected. See Quick Start Guide".
Downloaded Quick Start Guide which says: "connct LAN port to P4", "connect WAN to P1 or P2". Interestingly the accompaining picture seems ti indicate to connect the PC to P8...but let's just ignore it by now.
Very well, QSG says to connect port 4 and UM says to use 192.168.1.1. Let's assume that our client shall have 192.168.1.0/24 address. We don't have a PC ready in the datacenter but very easily can add a secondary IP to one of our servers...we done it milions of times...
NO WAY! USG310 does not respond...
Ok, let's check and connect all ports from 1 to 8, one by one, to discover that only port 3 was working.
So what? Logged in the web console…and...here it is: P3 had address 192.168.1.1, P4 192.168.2.1 and P5 192.168.3.1
Remember to always carefully read manuals before starting a setup…
