USG20W-VPN: Reach to maximum SSL VPN user
Hi.
We have the above appliance (firmware V4.33(ABAR.0)) with SSL VPN configured. I created a VPN group and added four uses to the group, enabled SSL VPN for this user group.
It worked at first, now I cannot login anymore because I get the error in title on the https webpage. On the logs I have:
The SSL VPN policy VPNSSL has been changed 'user' value.
User XXX(MAC=-) from http/https has logged in Device
User XXX from http/https has logged out Device
Failed login attempt to SSLVPN from http/https (reach the max. number of user)
Per specs the device should have 5 VPN users, and anyway there are 0 SSL VPN connected users. Why am I getting this error? Thanks
Hi @maxxer
Welcome to Zyxel community
Can you share the screenshot of the login user pages for us when the issue occur?
Go to Monitor > System Status > Login Users > Login Users to check the current user list
I just made a test and we managed to establish 2 concurrent SSL VPN connections (+1 backend admin). So either some connections remained pending or there's something else. I'll report back when the error happens again. Thanks for the feedback
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
