OpenVPN support for USG router ?
The USG router (USG40 for my case) supports L2TP, IpSec, and SSL VPN out of the box.
It does not seem to support OpenVPN.
Is there a way to add OpenVPN to it? Any plan from Zyxel to support it in the future ?
thanks
-antony
Hi @purelight01,
Currently ZyWALL/USG doesn't support OpenVPN.
Thanks for your suggestion and we will evaluate it in the future if it is beneficial.
See how you've made an impact in Zyxel Community this year!
https://bit.ly/Your2024Moments_Community0 -
Hi, is possible use any other VPN client (than SecuExtender) ?
Hi @kyssling,The VPN client software which are officially verified by Zyxel are ZyWALL IPSec VPN client and SecuExtender SSL VPN client.Other VPN client software/App could probably be used for VPN connection with ZyWALL/USG. However, these VPN client software/App from third party are not officially verified by Zyxel and there may be some interoperability issues.
Many VPN sollutions today supports openVPN. So could you plz take this into more concideration.
Hi @MAD
Is it possible to config a VPN Passthrough for open VPN?? In thath case I can buy a router that can handle the VPN and keep my netwrok config on the Zyxel ??0
Great @Zyxel_Vic now another question.
when setting up Ipsec IKEv2 VPN, I have a cetrificate provided by my VPN service provider, I cant manage to get it in under My Certifacates. Under Trusted no problems, but from there I cant select it.
Then under the IKEv2 config (Client role). I have a username ( email adress ). I cant change this as the VPN provider has this as optional. The @ seems not to be valid in your username field, is there a walkaround this.
plz PLZ help Meeeeee
@Zyxel_Vic Thanks for your help in this matter. And hopfully this new update will be soon
AND how about the certificate ?? The certificate i got fron my VPN provider is just a siple text file.
(-----BEGIN CERTIFICATE-----
xxxx
-----END CERTIFICATE----- )
Is there any way for me to use it on the USG60 ?? As i said above ther is no problems to load it in under Trusted certificates, but from there i cant select it when setting up the IKEv2 VPN client.
- 415 Beta Program
- 2.4K Nebula
- 152 Nebula Ideas
- 100 Nebula Status and Incidents
- 5.8K Security
- 287 USG FLEX H Series
- 278 Security Ideas
- 1.5K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 251 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 75 Security Highlight
