initial setup wizard
Hi, on my USG40 when I try "initial setup wizard" and click on CONNECTION TEST I get:
"Connection type is detected as DHCP but internet connectivity has failed because the device cannot get an IP Address"
why?
(USG40 connect to ISP router by WAN Port P1)
thank you
How are you connected to your ISP? do you get the WAN IP or is the ISP router doing NAT.
If you connect a PC to your ISP equipment do you get a IP WAN or LAN?
when I connect Directly pc to ISP router I get 192.168.1.171 (router has DHCP 192.168.1.170 to 190)
Hi @damianodec
Can you try to collect the packet on WAN and LAN and check if there is any DHCP packet go through the interface?
Here is the example how to collect packet.
GO to Maintenance > Diagnostics > Packet Capture > Capture to select the Capture Interfaces > click Capture
After doing the test, click stop and go to Maintenance > Diagnostics > Packet Capture > Files > select the files and click Download to check the packet on WAN & LAN
hi @Zyxel_Jerry
thank you for help.
Now I connect by another ethernet port on ISP router. This is my configuration office:
and it works.
my internal Lan is 192.168.1.xxx - 255.255.255.0.
on Wan1 gateway is 192.168.1.1 (ISP router).
I configured a SSL VPN and if I use from my home Secure extender with:
Server xxx.xxx.xxx.xxx:443 (xxx is my IP public) user and password
It connects but I see just lan 192.168.6.xxx
How can I to see lan 192.168.1.xxx ?
thank you
- 431 Beta Program
- 2.6K Nebula
- 164 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
