USG 40 - SSL VPN - disable multiple connection for user
kaika313
kaika313 Posts: 40 image  Freshman Member
edited April 2021 in Security
we're using SSL VPN to connect to a USG40.
Some users forget to click on disconnect after using the VPN and so, until the reauthentication Time is reached, sometimes it happens that a user connects again and the SSL VPN tunnels get all occupied soon with same users connected multiple times. Is it possible to prevent this?
Thank you
Kari
    PeterUK Posts: 4,267 image  Guru Member
    For each user you can set lease time to 2 minutes and in User/Group > settings you can check Enable user idle detection
  • kaika313
    @PeterUK Ok for the idle detection but (sorry for the stupid question) won't the reduced lease time disconnect the user or disturb active connections?
    Thank you
    edited March 2020
    The reduced lease time will renew if the user stays connected.
  • USG_User
    USG_User Posts: 400 image  Master Member
    edited March 2020
    How the USG conduct the idle detection, by scanning packets which are going through the tunnel? But a few packets will be transmitted through the SSL VPN tunnel also always without any user action.
    We are using a lot of SSL VPN tunnels, and when established, using RDP sessions to our office computers. Will this be detected by the USG as "not idle"?
  • Ian31
    Ian31 Posts: 174 image  Master Member
    @kaika313
    Here what I configure on my ZyWALL 110 to limit user account can only with 1 login.
    Oddly that "Reach maximum number per account" setting is not in USG40
