[NEBULA] VPN L2TP WITH NEBULA
STIENTAFIREWALL
STIENTAFIREWALL Posts: 1 image  Freshman Member
edited April 2021 in Nebula
I try to enable a VPN L2TP over IPSEC on NEBULA GATEWAY NSG50
but not working, I used as a Client Windows 10 1909 versione, but the error is
Unable to establish network connection between the computer and the VPN server, the remote server is not responding. The problem may be caused by a network device such as a firewall, a NAT protocol or a router, between the computer and the remote server, which is not configured to allow VPN connections. To find the device causing the problem, contact the administrator.
Please, can you help me?
Thank you
Davide
CED Administrator
  • ivers
    ivers Posts: 45 image  Freshman Member
    First Comment First Answer Friend Collector Fifth Anniversary
    edited March 2020
    @STIENTAFIREWALL
    Is your NSG located behind the NAT gateway? You will need to configure the port forwarding on UDP port 500 and 4500 (in NAT gateway).
  • Zyxel_Chris
    Zyxel_Chris Posts: 739 image  Zyxel Employee
    Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 50 Answers
    Hello @STIENTAFIREWALL
    Welcome to the community.?
    Is your issue still persist? If so, you can share the event log in the post, you can find event log at Security gateway> event logs, filtered as VPN.
Nebula Tips & Tricks
