[NEBULA] how do I configure a VPN network to access from laptop or cell phone?
Hi Zyxel Team,Mr_DJ said:Earth and others
It's all fine enough. And of course, I've made the settings that you show and tried with them before I write here and it still does not work. But now Zyxel support has gained access to the NSG where I have the problem, so we need to see if they find out what's wrong.And to those who could read this, I do not need more answers here.
Best regards
\Mr_DJ
I have spent the day for something which should be easy on the NSG50, and when I have read M_DJ trouble, I figure out that Nebula_Chris, you can help me on that same way you did with Mr_DJ !! (I am unable to use the L2TP over IPsec, I have tried the Nebula logon, the RADIUS server, with iOS VPN client, windows VPN client...) nothing is working
However I want to use the nebula cloud which is looking so powerfull when it works... and it would help my teamates which are asking me to be able again tomonitor the production line (a flour mill) from home !!
Hello @MaTT_T
Welcome to the community!!
Sure, I will help.
First of all, I want to know if your NSG is located behind the NAT server and your firmware status is up to date? (At Gateway>Security gateway)
can you share the full solution please this seems a common issue
Hello @accurro
The reason why MaTT_T fail to connect the tunnel is because the incorrect L2TP setting in Windows.
Is your L2TP setting looks like it?
On the other hand, if your NSG is located behind the NAT gateway, then please refer to this post will need to modify the registry setting in Windows then can support this scenario.
If still not work then please help me to screenshot the event log of VPN category.?
- 588 USG FLEX H Series
- 476 News and Release
