Content Filter interfering with Windows Updates
I posted this previously, but I'm still having problems with the Content Filtering interfering with Windows Updates. Problem occurs on both ATP and USG series. I haven't identified which category is the cause, but overall it shouldn't interfere regardless. Any help appreciated. Zyxel tech can your devs look at this? Thanks
Hi @iSpeed
We notice you report similar case on previous thread, would you please follow the instruction and send us the log to check what happened?
Go to Monitor > Log > View log click Show Filter
Filter the IP address and check if there is any related log on it?
Can you send your configuration file via private message?
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
