How can i log user access in usg40
carteo
carteo Posts: 6 image  Freshman Member
edited April 2021 in Security
i've the necessity to log when user from vpn login and logout and save the report, it's possible?
In a small company, around 15 users are using smart working and accessing their PCs via VPN. The boss asked me to know when each individual user logs in and how long he works. Is it possible to have this kind of report from the usg40?
Thanks in advance
data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABQAAAAUCAQAAAAngNWGAAAA/0lEQVR4AYXNMSiEcRyA4cfmGHQbCZIipkuxnJgMStlMNmeyD2dwmc8+sZgxYJd9ErIZFHUyYYD7fkr6l4/rnvmtl7+KitrqV/fq2Y5eLY3Z9S48eRLe7BmVZ9qhTLhQ0algzZWQOVKSsCF8OjAnwbxDTWFDUhPK/jMr1H6HE/IqRky2DyvCefuwItwZzodVoYRiLqMkVCXrwpJ9twZ+sgfDYEFYl8wIWxZ9uFf7zkallxlJh4YrLGsKjZRx7VGHhLqwgFUN45DGdb8MeXGpgB4ABZdeDcpZEY51A+hyLKz4S1W4MQWm3AibWtgWmk6dyISa1pSdyWTOlLXVp0+eL9D/ZPfBTNanAAAAAElFTkSuQmCC There was an error displaying this embed.
    You could setup the Email logs to log the following
  • USG_User
    USG_User Posts: 400 image  Master Member
    But the USG logscreen has only limited space and after a few hours or days the login information are getting lost.
    Don't know whether an USG40 is able to, but we are saving different logs on our USG110, including our SSL VPN user logins on an USG attached USB stick, where new log files will be created for each single day. Of course there will be saved a lot of other stuff into these log files, but we are able to search for VPN logins, if needed. It's a workaround for us.
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @carteo
    Yes, the log can be displayed on USG40
    Go to Monitor > Log > View Log and select category “User” or “ L2TP Over IPSec”
    Here is the FAQ of procedure to configure the email log
    https://businessforum.zyxel.com/discussion/926/the-procedure-to-configure-the-email-log/p1?new=1
