SSL VPN and gateway
hi,
I had configure on my company a VPN SSL connection and it works (I have a USG40)
I connect from house to my company.
In my company there is a windows 2019 server (192.168.6.10) and USG40 (192.168.6.254), on WS2019 there is a domain controller and all pc inside company get IP address from DHCP server.
this is VPN SSL configuration:
on DNS server 1 I put WS2019 IP address
when I connect notebook from my wifi house by Zyxel secuExtende I get this IP address:
but I'd like that gateway get 192.168.6.254 (USG40).
How can I do it?
thankk you fo help.
The gateway IP shouldn't matter but if you go to VPN > SSL VPN > Global settings tab in Network Extension Local IP put in 192.168.6.254
thank you @PeterUK
I need to connect my notebook from home to AD domain in my company. We have a application that need to internet connection to works.
from notebook in my home if I do not put 192.168.6.254 tha app does not work with that gateway it works.
I'd like that when I connect by SSL VPN my notebook link to AD domain inside company.
configuration validation test for my username inside ad domain is ok
I try by securExtender with this values
server: IP pubblic
username e password: the same to connect to ad domain
but it does not connect:
Really you should not overlap the VPN subnet in a subnet thats LAN1 but in a test I did.
LAN1 192.168.255.202/255.255.255.192
SSL range 192.168.255.194-192.168.255.195
Network Extension Local IP 192.168.255.202
thank you @PeterUK
hi @PeterUK for AD server how can I to solve?
Not sure about the AD server
- 441 Beta Program
- 293 Service & License
