[NEBULA] Bigger QR Code Labels
Hi @pitmancd
Thanks for your feedback! The latest version of the Nebula Mobile APP includes a Zoom option when scanning device QR code. Feel free to check it out and tell us the result.
Bayardo
Ok. It's been awhile, but I think last time I used the app and a small QR code it did work better. I know some devices can't have a big label because of the size of the device. And I think that some devices may come with an extra label that's printed on separate documentation?? But it seems like some devices only had the small label on the device itself, and the app struggled with being able to read it. I would just suggest making the labels bigger if possible and/or providing a bigger label on separate documentation in the box or on the box. Thanks!
Hi @pitmancd
Normally, you can find the QR code on the device, on the box and in the device local GUI, except for some old manufactured models that have been added to Nebula just recently. The new manufactured devices will include the QR code on the places mentioned before.
As mentioned, the latest APP version released in March support the Zoom-in for device registration.
Can you tell us with which devices you met this issue? So we can check that thoroughly. Thanks!
A good test would be the NWA1302-AC. Last time I remember the app working, maybe better than before, but it still seemed hit or miss to get it to work. And I don't think there were any larger QR code labels provided, whether in or on the box or attached to the device.
This is not necessarily a huge issue as I can of course enter things manually. It's just more of a nuisance and suggestion to keep in mind for future products.
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 317 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
