L2TP Phase 2 proposal mismatch
Christian78
Christian78 Posts: 8 image  Freshman Member
edited April 2021 in Security
Hi!
I have problems to set up a L2TP over IPSec VPN on my ZyWALL310 VPN.
I used both the Quick Setup to configure the VPN and I configured it manually from scratch. Always with the same result. It seems that Phase 1 of the negotiation works fine, but the log ends with:
[Default_L2TP_VPN_Connection] Phase 2 proposal mismatch
[SA] No proposal chosen.
I've attached some pics of my config. Any ideas?
Thanks for your help!
VPN Gateway:
VPN Connection:
L2TP Config:
Screenshot of log:
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    @Christian78
    For the log message: "Phase 2 proposal mismatch" which could be the Algorithm on VPN connection mismatch.
    Double check the Encryption and Authentication on the USG are match with VPN client's.
    PeterUK Posts: 4,273 image  Guru Member
    Try changing your proposal  to the following
    https://businessforum.zyxel.com/discussion/comment/10293#Comment_10293
  • Christian78
    Hi Peter, hi Charlie!
    Thanks for your suggestions! In fact, is was a mixture of wrong proposals and user management. I had great help yesterday from Zyxel support, who found out that my proposals were slightly wrong.
    Today, the tunnel is working perfectly. I am now trying to find out how to assign different User Groups to different Security Policies.
    In the L2TP Config, I've set "Allowed Users" to L2TP-Group, which is my preconfigured group of allowed Users.
    In the 2 Security Policies ("IPSec Outgoing to Any" and "IPSec to Device"), I've done the same: I've limited it to the L2TP-Group Users. But that causes trouble. The VPN is only set up when I set the Users to "any".
    I now 'only' need to figure out how to configure that part.
    Cheers,
    Christian
  • Jeremylin
    Jeremylin Posts: 166 image  Master Member
    First Answer First Comment Third Anniversary
    Just curious that why you want to configure it
