Site-To-Site IPSec VPN
Drum
Drum Posts: 2 image  Freshman Member
edited April 2021 in Security
How can I configure IPSec VPN Tunnel between USG60W and Cisco RV042G?
DDNS service is configured both routers.
USG60W:
WAN IP: usg60w.dyndns.org
Local IP: 192.168.100.1 255.255.255.0
RV042G:
WAN IP: rv042g.dyndns.org
Local IP: 192.168.200.1 255.255.255.0
    PeterUK Posts: 4,426 image  Guru Member
    edited April 2020
    on the USG60W side make a VPN gateway tab with IKEv1 may address wan1 with peer gateway rv042g.dyndns.org enter Pre-Shared Key and ok then go to VPN connection tab make for site-to-site select your VPN gateway set local policy 192.168.100.1 255.255.255.0 and remote policy 192.168.200.1 255.255.255.0 go advance and check nailed-up make a zone TuneltoRV042G and set that for zone in VPN connection.
    firewall rules
    allow FROM wan1 TO ZyWALL service VPN group ESP, IKE, L2TP-UDP and NATT
    allow FROM TuneltoRV042G TO LAN1
    allow FROM LAN1 TO TuneltoRV042G
