ZyWALL as a client connecting to a VPN server
The first issue,the username cannot accept with "dot" on client mode.
Also, if you want toconfigure VPN tunnel interface, you need to select static IP on phase 1.
Currently, device cannot support this behavior. We will discuss and evaluate it internally.
5
It seems does not possible, since the VPN remote policy can't fill FQDN(fr.freel2tpvpn.com) on Zywall.
Doing some testing theirs a bug for adding Enable Extended Authentication Client Mode with user name freel2tpvpn.com from saving as it has a dot.
So I got my VM setup with Remote Access (Server Role) with the following on ZyWALL 110
I then want to connect to that VPN over cellular1 on my VPN300 and this is how I set that up and the first problem is VTI does not allow Dynamic Address and the following does not connect.
5
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
