zyxel usg 60w vpn l2tp over ipsec session ends in 30 minutes.
I noticed that the connection to vpn will be lost. He began to understand, found a pattern: every time exactly 30 minutes and shutdown. Checked on other clients, the result is the same.
Router# show session timeout udp UDP session connect timeout: 60 seconds UDP session deliver timeout: 300 seconds Router# show session timeout tcp TCP session timewait timeout: 5 seconds TCP session close timeout: 10 seconds TCP session closewait timeout: 60 seconds TCP session established timeout: 9000 seconds TCP session finwait timeout: 120 seconds TCP session lastack timeout: 30 seconds TCP session synrecv timeout: 60 seconds TCP session synsent timeout: 120 seconds Router# show session timeout icmp ICMP session timeout: 15 seconds
Tell me what and where to look?
It is resolved. The problem was user properties.
change keep alive timer to 1
In L2tp vpn? - Didn't work
- 601 USG FLEX H Series
- 480 News and Release
