OpenVPN support for USG router ?
I just lost a deal on 2 ATP500 because they don't support Open VPN! This must be an easy fix.
Regards
/Robert1 -
I'm with Robert!!
Currently ZyWALL/USG doesn't support OpenVPN.
Thanks for your suggestion and we will evaluate it in the future if it is beneficial.
Another customer that also needs OpenVPN support on Zywall USG110 and USG40. It's beneficial to everyone that wants to configure a VPN provider that uses OpenVPN on their ZyWall USG device. Please implement this asap zulu.0
I just made an account on this Forum so I can make someone from Zyxel_support say:Currently ZyWALL/USG doesn't support OpenVPN.We will evaluate it in the future.
Please do evaluate this in the near future0 -
I'm a longtime Zyxel business customer in USA and am also advocating for OpenVPN for the USG and ATP series security appliances. This Forum topic began 1.5 years ago, so customers interpreting Zyxel comment of "in the future" may be getting restless as I am, and may possibly start looking elsewhere for an OpenVPN hardware supplier solution. Thanks Zyxel.0
Hi @swimmer
Thanks for your asking. On USG/ATP series, we so far have no plan on OpenVPN application so far, however, the Zyxel Armor G1/G5 can do it.
Here it is the product information for your reference:
https://www.zyxel.com/products_services/AC2600-Multi-Gigabit-WiFi-Router-ARMOR-G1/overview
https://www.zyxel.com/products_services/AX6000-12-Stream-Multi-Gigabit-WiFi-6-Router-ARMOR-G5/
BR0 -
Zyxel_Vic said:Hi @swimmer
BRNice you have product information about openVPN on ARMOR G5. You are aware it is not working, because you have to activate DDNS. Unfortunately DDNS xxx.zyxel.me do NOT support router ARMOR G5. Product advertisment is not enough for a solution.waiting for update(
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 319 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
