Geo IP
I'm playing around with Geo IP, to block traffic from certain countries.
Do you need to setup an 'Address Rule' based on GEOGRAPHY for every single country you would like to block? Or it there a 'thick box' functionality hidden somewhere.
It's a bit of a time consuming exercise to create every single country you would like to block, and add them to a group. A wizard where you can thick the countries, and the 'action' would be a good alternative.
Hello Sulcus,
Just double confirm your request,
you want the feature which can make countries to be a group at once, so you dont need to setup an 'Address Rule' based on GEOGRAPHY for every single country then add them to a group.
Charlie0 -
Hello Charlie,
i think, you are right with your request confirmation. I can confirm his question and your confirmation information.
it's not comfortable to create per country ONE address-object, and after this, you can create a address-group to add the GEO-IP based objects in the address-group object.
Is there a FMO (Future Monde of Operation), where the GEO-IP objects are by default embedded and can be added to a address-group object. That can safe time and is a more comfortable handling the GEO-IP management
Best regards
Christian
Hello Sulcus,
The request "the feature which can make countries to be a group at once", I would like to move your request to the ideas section.
Charlie0
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
