4G network slow on USG 60
I have a 4G+ router (dual band) and it works well if I use its own wifi.
However, if I connect the router by ethernet cable to the USG 60 (WAN PORT) occurs one problem: there is a very long delay for any external connection: there are many seconds (from 5 to 15) before webpage opening, or speed test starting. Once start, the speed is good (30-40 mbps).
Are there any setting on USG 60 I have to do?
@Franc
If your PC is under USG 60's lan, and access to internet in secs for the starting, you need to check your DNS setting. You could be followed it to try first.
Go to Domain Zone forwarder
Set DNS server on Lan interface
5
@Franc
5 -
Dear Charlie,
THANK-YOU VERY MUCH. It works very well.0
- 441 Beta Program
- 210 Nebula Ideas
- 540 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
