limitation SSL VPN on USG20
Best Answers
Is any of the simultaneous connection using a separate VPN login credentials? Or do the connections using the same User/PW combination?
5 -
Check Configuration | Object | User/Group | Tab Setting: Here you could find the section User Logon Settings. Maybe there are some limitations for simultaneous logons for an access account.
6
5 -
Yes We have 15 users with 15 separates Login but it is possible, we are 35 in our lab, that sometime we have 2 users with the same login.Is it the problem?0
6 -
OK thanks I look after the settings
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
