ZyWall USG20 - Old - VPN Setup
MatteoBasso
Hello everybody
I Have a ZyWall with Firmware 3.30(BDQ.5) 15/05/2014.
I Can't set-up VPN via L2TP. All the guides I have read or watched on Youtube has different method, maybe because the firmware is newer and little bit different.
Anyway, trying some solutions I can't connect.
Has Anyone a guide that could help me?
The Wizard doesn't have the L2TP option but only
VPN Settings for Configuration Provisioning
Please help me.
Thank you
VPN Settings
- The later steps will guide you to setup the VPN.
- - Wizard Type
- - VPN Settings
- - Wizard Completed
VPN Settings for Configuration Provisioning- The later steps will guide you to setup the VPN.
- - Wizard Type
- - VPN Settings
Please help me.
Thank you
@matteosaitta
Go to VPN Settings>Express>Select Remote Access(Server role)>Enter the preshare key and local policy(Wan IP)>Press save
Go to the VPN> Ipsec VPN>VPN connection>Select rule you created>Create the address for local policy(Wan IP)
Go to L2TP> Select VPN connection rule, IP pool for l2tp client and allow user
Note: If established l2tp tunnel with Iphone, please select the related algorithm.
On VPN gateway profile,
On VPN connect profile,
@Zyxel_Charlie
Thank you for the reply. I have tried to do as suggested but doesn't work.
Let me show you....
1) VPN Connection
WIZ_VPN
I have created ad object named WAN as you told me, putting the firewall's public IP adress , than I have added the various Encryption proposals
So on VPN Gateway section I just putted the Pre-Shared Key and the Encryption list like the one before.
Finally on L2TP Section I Have created a "test" user with a password, an IP address pool.
Unfortunately it doesn't work. I don't know If I have to set something on Firewall rules.
Please help me,
thank you,0
- 599 USG FLEX H Series
- 480 News and Release
